Epox 8K3AP http://www.epox.ru/downloads.php?file=/data/download/bios/8K3A3916.zip BIOS Patcher ver. 6.00.alpha_10. |for Award/Phoenix
Epox 8K3AP
BIOS Patcher ver. 6.00.alpha_10. |for Award/Phoenix & AMI bioses|
Found 2Mbit Award BIOS (6.x)!
Found AMD K7-BIOS/platform!
1. New CPU Support           : -> fixed.
Mobile AMD Multipl-r adding  : -> fixed.
Adding AMDK7NOW! support     : -> fixed.
2. XP frequency              : -> fixed.
3. New Koeffs Support        : is not needed to be fixed.
4. 32Gb-problem              : not found.
5. Some HDD detect-problem   : not found.
6. "MB"/"GB" string search   : is not needed to be fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x  : not found.
11.New Stepping Support      : is not needed to be fixed.
12.Tualatin L2-init error    : not found.
13.New Freq in Setup open    : found, but Unknown format!
14.Set "Y" as default on exit: not found.
Tweak options addinng:
1a.CPU MSRs Init (s2k2bp.ini): -> fixed.
Bus Disconnect Support       : -> fixed.
Display Features adding      : -> fixed.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp  47.7%
Adding start.tmp  87.5%
Adding tweak.tmp  45.2%
(c)2002-2004 apple_rom, www.ROM.by
Проц Thorton 2400+, замобилен. После прошивки все фичи работают, множитель меняется во всех направлениях, глюков не замечено. :P
Версия 6.00 - обкатка (часть 2)
