Кстати, выкладываю, как и обещал, тест и бенч
Кстати, выкладываю, как и обещал, тест и бенч HotCPU (смог машину "выдернуть" для прогона только на 4 часа, не обессудьте):
Hot CPU Tester Pro(Lite Edition) 4.1.1.565
Copyright © 1999-2003 7Byte Computers
Monday, March 01, 2004 - 07:20:14
Diagnostic Report
Test Started at: 03:18:01
Test Duration: 04:00:01
Physical Processors Available: 2
Logical Processors Available: 2
Multi-Processors System(SMP): Not Available
Hyper-Threading Technology: Not Available
CPU Name String: Pentium® III (0.13 µm) With 256 Or 512 KB On-Die L2 Cache
Speed: 1627MHz
Logical Processors Tested: CPU 0, CPU 1
Average CPU(s) Performance: 100.0%
Modules Results:
Complex Matrix: Finished without error
Calculating Pi: Finished without error
Sorting Algorithms: Finished without error
Prime Test: Finished without error
Fast Fourier Transforms:
Chipset:
L1 Cache:
L2 Cache:
Memory: Finished without error
HD: Finished without error
MMX: Finished without error
SSE:
SSE2:
3DNow!:
Hot CPU Tester Pro(Lite Edition) 4.1.1.565 - Benchmark Result
Monday, March 01, 2004 - 07:23
Overall : 4418
MetaBench to MHz ratio : 2.72
Integer Instructions : 370 M Instructions/s
Floating-point Instructions : 532 M Instructions/s
MMX Instructions : 703 M Instructions/s
SSE Instructions : 276 M Instructions/s
SSE2 Instructions : N/A M Instructions/s
3DNow! Instructions : N/A M Instructions/s
Memory fillrate memcpy method : 423 MB/s
Memory fillrate C++ method : 366 MB/s
Memory rep movsd : 421 MB/s
Memory FPU 8 bytes blocks : 368 MB/s
Memory Assembly 4 bytes blocks : 366 MB/s
Memory Assembly 8 bytes blocks : 366 MB/s
Memory fillrate MMX 8 bytes blocks : 368 MB/s
Memory fillrate MMX 16 bytes blocks : 370 MB/s
Memory fillrate SSE 16 bytes blocks : 368 MB/s
Memory fillrate SSE movntq 8 bytes blocks : 577 MB/s
Memory fillrate SSE movntq 16 bytes blocks : 582 MB/s
Memory fillrate SSE prefetch movntq 16 bytes blocks : 604 MB/s
Memory fillrate SSE movntps 16 bytes blocks : 583 MB/s
Memory fillrate SSE prefetch movntps 32 bytes blocks : 606 MB/s
Memory fillrate SSE2 prefetch movntps 16 bytes blocks : N/A MB/s
Insertion Sort : 32 K Items/s
Shell Sort : 754 K Items/s
Merge Sort : 1,465 K Items/s
Heap Sort : 727 K Items/s
Quick Sort : 3,355 K Items/s
Large Objects Sort : 773 K Items/s
Fast Fourier Transformg (Standard) : 3,598 KB/s
Fast Fourier Transformg (Optimized) : 6,748 KB/s
Проблемы с ECS D6VAA (продолжение)
  • Есть мнение, что в этом случае цифровмк не
  • 2apple_rom Касательно некорректного определения процессоров - подметил
  • Насколько мне известно, у целеронов IOQD=4, насчет
  • давай фотки можно в мыло .. попробуем
  • 2apple_rom Спасибо за ответ и извиняюсь за
  • С3 - см. память. 25-26 - см. генератор/частоту. "непонятные то
  • Забежал продложить "записки сумасшедшего" всегона пол-минутки: некогда, сревер
  • Я НИЧЕГО НЕ ПОНИМАЮ... :? На что я
  • Welcome!!!
  • Привет, ALL , начинаю выкладывать тесты, как
  • Глюкавую память заменил, все встало на свои места;
  • Ха, ну это-то у нас, дядьку,
  • По поводу RAID .. все должно заработать ....
  • Кстати, дополнительный вопрос 2ALL , особливо к
  • Мой тебе совет - если у них осталась
  • AIDA тоже подалась в гадалки...
  • Ура, ура, ура!!! Так и хочется сказать - твою
  • ты посмотри что AIDA говорит
  • Ты тетку Сандру больше слушай, она тебя еще
  • Елы-палы, перечитал все написанное собой же
  • Кажется, поймалась первая "блоха": запустил с CD Windows
  • С каким бы удовольствием я сейчас что-нибудь разломал
  • Удачной охоты (в смысле на глюки платы)
  • Температура на процессорах 35-36 по Цельсию, кондюки здоровее
  • Все-таки не в БИОСе мне кажется дело. Обычно
  • Залил новую прошивку, только с /v; система пока
  • Зараза такая - тест прошла, отрепортилась... и вылетела!
  • Выставил память на HostClock+8/10ns+3CL, начал грузить "сверху вниз",
  • При тесте памяти под Мастдаем в Turbo Mode
  • 2Макс Старина, если б я уже сам
  • Я вот что подумал: может при дуале в
  • W2K3 встал, и даже не заметил, что во
  • Похоже, что кто-то (и кажется я даже знаю,
  • Случайно глянул в Hardware Monitor: это
  • "Так Вам с шашечками или чтобы ехало?" (из
