Есть мертвая FireWire 410. Заменил TSB41AB2, признаки жизни
Есть мертвая FireWire 410. Заменил TSB41AB2, признаки жизни начала подавать. Консоль попросила прошивку, дал. Прошилась, загрузилась, но по прежнему не работает. При попытке запустить дебаг 1394 - виснет:
DM1000 Bootloader XE39
A-PHY
GUID: 000d6c01'000c222f
MAC: 0007f5-021005
HWID: 00000002
HWVS: 00000001
Bootloader: CRC ok! Id=00000001, V=00002705, 20030404-134625UT
Debugger: CRC ok! Id=00000000, V=00000000, 20021105-111225UT
Image: invalid
CnE: CRC ok! Id=00010046, V=00ffffff, 20070504-102656UT
Press Ctrl-A to avoid starting image!
Testing RAM address 0x10000000 length 0x00100000. Ok.
1) Download Image and Config (CnE)
2) Download Image only
3) Do RAM test
4) Start Image
5) Start 1394 Debugger
6) Mark Image as invalid
7) Print Flash Info
Bootloader (return=help) >
Download Image only
Erasing Flash ...
Start 'Send File' via XModem now ... [Ctrl-D Ctrl-D to cancel]
(choose .bcd file to download)
CC
Total 8745 blocks / 1136720 bytes.
End of transfer - received 1119116 bytes.
Identifier = 0x446f4362
Flags = 0x00000001
Date/Time = 20070504102656
Soft ID = 0x00010046
Soft Vers = 0x00ffffff
Hard Comp = 0x00000004
Info = FW 410# M-AUDIO#
CRC of burned image ok!
Image: CRC ok! Id=00010046, V=00ffffff, 20070504-102656UT
3) Do RAM test
4) Start Image
7) Print Flash Info
Addr=20080000. Ready ...
GO!
mod: SysDevUart2
mod: shellModule
mod: stack1394NoBusReset
mod: bldCommand
mod: modCMP
mod: Services1394
mod: AVCStack
mod: AVCConnectionMgnt
mod: HighSpeedCtrlService
mod: avDriver
mod: streamingDriver
mod: StreamingFrmWrk
mod: DataStreamManagement
mod: StreamingFramer61883
mod: modBmCommand
mod: modOsCommand
mod: Application
LibraryVersion: BeBoB FW410 App (Release)
LibraryBuildVersion: PRIVATE-BUILD
LibraryCVSTag: UNKNOWN-CVS-TAG
Using serialized printf
System initialisation done.
New Synch Mode: Internal
CMDLINE tool ready for commands. Try "help" for help.
/cfg>10 channel standalone plaD▒10 channel standalone playback processing is running
help
26 Available commands:
help help - shows help
rd rd - reads values starting at
wr wr - writes to
ls ls [-r|-x|-c] - shows content of current directory
cd cd - changes directory to
pwd pwd - shows current path
get get - reads value of
set set - writes to config
cfg cfg setdefault- resets configuration to factory settings
bat bat
shell shell [-h|-i|-o|-s] - shell configuration
dbgprt debug print commands
AVCLog controls the AVC stack logging
avc avc [econn, iconn]
bm busreset, nodes, rd, wr, wrs, lock, phywr, phyreg
cmp busreset, nodes, rd, wr, wrs, lock, phywr, phyreg
os [help, th, load, sem, blk, byte, timer, q, evf, evt, map, wp]
sys [help, llc, mdbsettings, mdbdump, dma, pic, cp15, reset, clock, stat, ver, info, frm, tgen, av, uart, spi, gpio]
route route a stream from an input plug to an output plug
level set the level of line out and mic gain
samplerate set sample rate: (44.1kHz = 1, .. 192kHz = 6)
spdif set SPDIF in: (OFF = 0, ON = 1)
duplex starts full duplex process
spdifSel select SPDIF input: (OPT = 0, COAX = 1)
msu Music Subunit Access
/cfg>cfg setdefault
resetting...done
/cfg>sys reset
A-PHY
MAC: 0007f5-021005
HWID: 00000002
HWVS: 00000001
Skip RAM test.
3) Do RAM test
4) Start Image
7) Print Flash Info
Addr=20040000. Ready ...
GO!
Вопрос к знатокам : в каком направлении рыть? TSB41AB2 заведомо новый, исправный поставил. Пайку прозвонил - все ок.
Дебаггер шины 1394 виснет, комп упорно не видит карту.
Оживление FireWire Solo
  • Ну дак есть у нас теперь Baza- ему
  • Пока читал, чуть голова не поломалась))) Ни черта
  • Обе карты дождались наконец-то микросхем и ожили. просьба владельца
  • http://www.rom.by/forum/Focusrite_Saffire_LE_-_pobeda вот тут по настройке порта http://www.rom.by/forum/Remont_i_pereproshivka_zvukovoj_karty_Infrasonic_Windy_6?page=1 тут тоже я расписывал
  • Всем привет! У меня M-Audio Audiophile FW. Тоже сдохла, комп
  • Удалось все-таки оживить???
  • Надо просто заменить чип, прошивка его сама отконфигурит.
  • А возможно починить все таки? Не проблема достать
  • Дело не в прошивке, а в сдохшем TSB41AB2
  • пока грешу на чип FireWire по нему есть пара
  • брось-ка сюда или асю лог порта и >help по
  • Baza Если речь о той самой Соло,
