У меня: BIOS Patcher ver. 4.23. Attention! Advanced qualification
У меня:
Found 1Mbit BIOS!
1. New CPU Support           : -> fixed.
2. P3-detect error           : not found.
3. New Koeffs Support        : -> fixed.
4. 32Gb-problem              : -> fixed.
5. Some HDD detect-problem   : -> fixed.
6. "MB"/"GB" string search   : -> fixed.
7. 65Gb-problem (1-st step)  : -> fixed.
8. 65Gb-problem (2-nd step)  : -> fixed.
9. Error display Freq>999MHz : -> fixed.
10.Error display Koefs>9.5x  : not found.
11.New Stepping Support      : -> fixed.
12.Tualatin L2-init error    : -> fixed.
13.New Freq in Setup open    : not found.
14.Set "Y" as default on exit: -> fixed.
UDMA for "big"-HDD on UDMA33_only_MB fix: -> fixed.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
[CPUCODE] ROM is releaseCBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp  35.5%
Adding start.tmp  87.5%
Adding cpucode.bin  53.6%
(c)2002-2003 apple_rom, www.ROM.by
Патчер - BP 4.23
CBROM - 1.07
LHA + микрокоды....
запускалось (с жесткого диска) G:\CHM\!! под винтукеем (W2kSP2 Eng)
Как видите, все нормально патчится, поэтому ищите ошибку у себя...
ошибка процесса пропатчивания в конце
