Доброе время суток! Кого-то еще интересует эта тема?
Доброе время суток! Кого-то еще интересует эта тема? Почитал даташит Intel 25068607.pdf на P4-M Mobile:
7.3 Enhanced Intel SpeedStep Technology
The Mobile Intel Pentium 4 Processor-M, when used in conjunction with the requisite Intel SpeedStep technology applet or its equivalent, supports Enhanced Intel SpeedStep technology. Enhanced Intel SpeedStep technology allows the processor to switch between two core frequencies automatically based on CPU demand, without having to reset the processor or change the system bus frequency. The processor has two bus ratios and voltages programmed into it instead of one and the GHI# signal controls which bus ratio and voltage is used. After reset, the processor will start in the lower of its two core frequencies, the “Battery Optimized” mode. An operating mode transition to the high core frequency can be made by setting GHI# low, putting the processor into the Deep Sleep state, regulating to the new VID output, and returning to the Normal state. This puts the processor into the high core frequency, or “Maximum Performance” operating mode. Going through these steps with GHI# set high, transitions the processor back to the low core frequency operating mode. The processor will drive the VID[4:0] pins with the VID of the current operating mode and the system logic is required to regulate the core voltage within specification for the driven VID.
в обозначения выводов:
The GHI# signal controls the selection of the operating mode bus ratio and voltage in the Mobile Intel Pentium 4 Processor-M. On the Mobile Intel Pentium 4 Processor-M featuring Enhanced Intel SpeedStep technology, this signal is latched on entry to Sleep state and is observed during the Deep Sleep state. GHI# determines which of two performance states is selected for operation. This signal is ignored when the processor is not in the Deep Sleep state. This signal should be driven with an Open-drain driver. Refer to the Mobile Intel Pentium 4
Processor-M and Intel 845MP/845MZ Chipset Platform Design Guide for termination and connection guidelines.
Я в английском не очень. Правильно понял: сначала перевести процессор в Deep Sleep, потом поставить сигнал GHI# в Low, потом вывести проц из Deep Sleep. И тогда multiplier станет не 12, а максимальным (в зависимости от модели проца)? Но перевести в Deep Sleep сложно. Видно придется гнать шиной. Кстати, здорово подходит кулер от боксового перскотта P4. Только подложить под защелки нужно прокладки 1,5-2,5 мм толщиной.
установка мобильного камня на десктопную мать
  • Попытался я было без отгибания ногу заземлить.
  • CENTRINO! (а каким "боком" он к s478 "прилеплен"???
  • В соответствии с технологией Intel Speed Step мобильные
  • Да, именно, так, как констатировал "rgt"-"Добрый Шаман" -
  • Разгон мобильного процессора Dothan в настольной системе
  • Treo При обсуждении этих вопросов в
  • . А изоляция соответствующей ноги, собственно и будет
  • Treo Вообще говоря L всегда означало
  • Простите, пока Вы еще мат. часть штудировать
  • Посты, так посты. (после некоторого ковыряния в даташитах
  • Будьте поосторожнее в приводимых Вами ссылках на
  • evi Если не сложно, взгляни, есть
  • i845PE, Platform Design Guide, раздел 12 "Platform Clock
  • Так в чем же МОЕ противоречие? В том, что
  • evi Вы сами себе противоречите. Производители
  • 1. По поводу mATX. Увы, еще по практике
  • Глубокоуважаемый "MmM"! Перед тем, как кого-либо отправлять "учить матчасть",
  • 845 в принципе не может поддерживать 200
  • Так это, полноформатных АТХ-плтат, поддерживающих понижение питания
  • Неплохая мамка оказалась Albatron PX845PEV v800
  • А с мультипликатором побороться есть какие-нибудь варианты?
  • 1. "Ноги" С процессором вроде все ясно. Дорогое удовольствие.
  • О, оригинальная идея. У меня как раз
  • А вы плотность и толщину ног на
  • Все тем же - МГТФ и руками,
  • Но ведь это только пол пути, а
  • Treo Снова повторюсь: в "Ремонте матплат",
  • А использовать старинный способ запуска туалатинов не
  • 1. По поводу напряжения VCore, кажется, я все
  • Вот это обнадеживает. Попридержу еще этот конструктор
  • Хоть к гуру себя и не причисляю, но
  • Я использую Intel P4-M 1800Мц вместе с ASUS
  • На этой неделе проходит осенний Intel IDF.
