Интересная штучка, вот что про неё пишут.
PC power supply supervisor with 3.3V/5V/12V UVP ,OVP and OCP check. OTP or FC or PWM output function are built-in
The WT7517 is semiconductor integrated circuits designed of Server System switching power supply.
It provides protection circuits, power good output (PGO), fault protection latch (FPOB), and a PSONB
 control.The Over Voltage Detector (OVD) and Under Voltage Detector(UVD) are
monitorV33, V5, V12A, V12B
within WT7515-N16 and external control VXOV and VXUN
within WT7517-N18.The Over Current Detector (OCD)monitor IS33,IS5,IS12A and IS12B
 within WT7517-N16 and external control IX and VX within WT7517 shall restart power automatically.
WT7517-N161 has FAN C function in OTP/FC pin. The output PWM is active low
Вот N 164 там нет.
Давайте фото .
Михаил.
Thermaltake 520W-AP (p/n w0073re) завышены выходные напряжения (решено)
