You can read my AMD FAQ in
You can read my AMD FAQ in English and ask questions after, if something is not clear for you from there.
is there any newer bios patcher than BP_6_A10 ?
No. This project is suspended for some time.
also for some strange reason I cant go >120MHz fsb with A7V133
Looks like you have troubles with PCI/AGP frequency dividers. If you set FSB to 133 - you have divider 4 for PCI and 2 for AGP, resulting in standard 33/66MHz. But at 120 you most probably have 1.5 and 3, giving 80MHz on AGP and 40MHz on PCI. That is beyond normal and may be not acceptable for devices like IDE controller or AGP cards.
Duron1800 + ASUS A7V-M (KT133) - что можно сделать
