Тогда, может, сначала в раздел Хочу
Cramac писал(-а):
Много где уже облазил, не нашел прошивки на эту мать:(
Тогда, может, сначала в раздел "Хочу прошивку" ? roll
добавил позже :
по идее, у Вас этот БИОС ...
и такой (примерно) лог :
BIOS Patcher ver. 4.23.
Found 1Mbit BIOS!
1. New CPU Support           : -> fixed.
2. P3-detect error           : is not needed to be fixed.
3. New Koeffs Support        : -> fixed.
4. 32Gb-problem              : -> fixed.
5. Some HDD detect-problem   : -> fixed.
6. "MB"/"GB" string search   : -> fixed.
7. 65Gb-problem (1-st step)  : -> fixed.
8. 65Gb-problem (2-nd step)  : -> fixed.
9. Error display Freq>999MHz : is not needed to be fixed.
10.Error display Koefs>9.5x  : not found.
11.New Stepping Support      : is not needed to be fixed.
12.Tualatin L2-init error    : not found.
13.New Freq in Setup open    : not found.
14.Set "Y" as default on exit: -> fixed.
Write Allocate addinng: not found.
UDMA for "big"-HDD on UDMA33_only_MB fix: not found.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp  30.5%
Adding start.tmp  87.5%
(c)2002-2003 apple_rom, www.ROM.by
