6BX7 USER S MANUAL 1. CPU Over Voltage Protect (Magic
6BX7
USER'S MANUAL
1. CPU Over Voltage Protect (Magic Booster).
2. System power on by PS/2 Mouse: First, enable this function
in CMOS Setup, then you can power on the system by double
clicking the right or left button of your PS/2 Mouse.
3. System power on by Keyboard: If your ATX power supply
supports larger than 300 mA 5V Stand-By current (depends
on the specification of keyboards), you can power on your
system by entering password from the Keyboard after setting
the “Keyboard power on” jumper and password in CMOS
Setup.
4. Support 3 steps ACPI LED selectable.
5. Support Modem Ring-On. (Include internal Modem and
external modem on COM A and COM B)
6. Support Wake-up On LAN. (Your ATX power supply
1.2. KEY FEATURES
q Intel CeleronTM/Pentiumâ!!! Socket 370 Processor based PC/AT
compatible mainboard.
q Intel Pentiumâ !!! 100/133MHz FSB, Coppermine core FC-PGA
Intel CeleronTM 100MHz FSB, Mendocimo core PPGA
Intel CeleronTM 66MHz FSB, Mendocimo core PPGA
q Socket 370 Pins ZIF white socket on board.
q Supports CeleronTM/ Pentiumâ!!! Socket 370 processor running at 300-866
MHz.
q INTEL 440BX chipset, Supports AGP / SDRAM / Ultra DMA/33 IDE /
Keyboard and PS/2 Mouse Power On / ACPI features.
q Supports 3xDIMMs using 3.3V SDRAM DIMM module.
q Supports external Modem Ring-On on COMA & COMB and internal Modem
Ring-On.
q Supports SDRAM 16MB ~ 768MB memory on board.
q Supports Wake-up on LAN.
q Supports ECC or Non-ECC type DRAM module.
q 1xAGP slot, 5xPCI Bus slots, 2xISA Bus slots.
q Supports 2 channels Ultra DMA/33 IDE ports for 4 IDE Devices.
q Supports 2xCOM (16550), 1xLPT (EPP / ECP), 1x Floppy port.
q Supports 2XUSB port & PS/2 Mouse/ Keyboard port.
q Licensed AWARD BIOS, 2M bits FLASH ROM.
q 30.5cm x 19 cm ATX SIZE form factor, 4 layers PCB.
22. Pentiumâ !!! 800 / 133 MHz FSB
SW1
ON
4 3 2 1
ON SW2
1 2 3 4 5 6
23. Pentiumâ !!! 866 / 133 MHz FSB
SW1
ON
4 3 2 1
ON SW2
1 2 3 4 5 6
J17: Cyrix CPU Turbo Function (Optional)
Это вырезки из инструкций))
Novyj_tochechnyj_risunok_3ffff.jpg 56.5 КБ
