Вот что выдал Iflash.exe от платы D845GVAD2: Intel
Intel Flash Memory Update Utility  Part 643643-046
    GUI-mode options:
        /m - Monochrome display            /b - Use BIOS video calls
        /t - Use EGA/VGA line count        /n - Do not use pointer device
    Command-line mode options:
        /h - Help (this text)
        /q  - Quiet mode; errors only, and no prompts
        /qb - Quiet mode; No beeps
    Standard options:
        /r - Force reboot after update     /@ - Use override file
        /f - Force CMOS defaults next POST /d - Verbose debugging output
        /c - Clear ESCD (Extended System Configuration Data) next POST
        /p pathname  - Program FLASH device with contents of 'pathname'.
        /pu pathname - Program User Binary area with contents of 'pathname'.
        /v pathname  - Verify current FLASH with contents of 'pathname'.
        /sX pathname - Save resident FLASH area to 'pathname' (or 'vvvv'BIOS),
                       X = { 'B'IOS, 'L'anguage, 'U'ser, or 'R'ecovery } area.
        /x pathname  - eXamine FLASH header of 'pathname'.
    Special Operations:
        /v pathname  - Verify current flash with contents of 'pathname.'
        /x pathname  - eXamine flash header of 'pathname'.
        /sX pathname - Save resident flash area to 'pathname' (or 'vvvv'BIOS)
               X = { 'B'IOS, 'L'anguage, 'U'ser, 'R'ecovery } area.
        /ae - Erase OEM CMOS Defaults.
        /ac - Copy Custom CMOS Defaults into the OEM CMOS Defaults.
        /af - Force OEM CMOS Defaults next POST.
        /ag pathname  - Get OEM CMOS Defaults to 'pathname'.
        /as pathname  - Set OEM CMOS Defaults with contents of 'pathname'.
        /ew pathname  - Write BMI settings with contents of 'pathname'.
        /er pathname  - Retrieve BMI settings to 'pathname'.
