Продолжаем: Особенно мне нравятся две первые строки бенча
Продолжаем:
Hot CPU Tester Pro 4.0.0.578 - Benchmark Result
Saturday, April 24, 2004 - 01:41
Overall : 4375
MetaBench to MHz ratio : 2.78
Integer Instructions : 367 M Instructions/s
Floating-point Instructions : 518 M Instructions/s
MMX Instructions : 738 M Instructions/s
SSE Instructions : 275 M Instructions/s
SSE2 Instructions : N/A M Instructions/s
3DNow! Instructions : N/A M Instructions/s
Memory fillrate memcpy method : 455 MB/s
Memory fillrate C++ method : 440 MB/s
Memory rep movsd : 454 MB/s
Memory FPU 8 bytes blocks : 438 MB/s
Memory Assembly 4 bytes blocks : 441 MB/s
Memory Assembly 8 bytes blocks : 441 MB/s
Memory fillrate MMX 8 bytes blocks : 438 MB/s
Memory fillrate MMX 16 bytes blocks : 441 MB/s
Memory fillrate SSE 16 bytes blocks : 439 MB/s
Memory fillrate SSE movntq 8 bytes blocks : 482 MB/s
Memory fillrate SSE movntq 16 bytes blocks : 482 MB/s
Memory fillrate SSE prefetch movntq 16 bytes blocks : 482 MB/s
Memory fillrate SSE movntps 16 bytes blocks : 482 MB/s
Memory fillrate SSE prefetch movntps 32 bytes blocks : 481 MB/s
Memory fillrate SSE2 prefetch movntps 16 bytes blocks : N/A MB/s
Insertion Sort : 31 K Items/s
Shell Sort : 787 K Items/s
Merge Sort : 1,512 K Items/s
Heap Sort : 878 K Items/s
Quick Sort : 3,385 K Items/s
Large Objects Sort : 933 K Items/s
Fast Fourier Transformg (Standard) : 2,363 KB/s
Особенно мне нравятся две первые строки бенча (Overall и MetaBench to MHz ratio)... wink
