1.01.1997 0:03:33
 1.01.1997   0:03:33
 1.01.1997   0:03:33
 1.01.1997   0:03:33    | MHDD 4.6 (c) Dmitry Postrigan | FREEWARE
 1.01.1997   0:03:33   Changing mode to: IDE
 1.01.1997   0:03:34
 1.01.1997   0:03:34   MHDD>SCAN
 1.01.1997   0:03:34   FUJITSU MPF3204AH  LBA: 40,032,696
 1.01.1997   0:03:34   SN: 01187773  FW: 5C14
 1.01.1997   0:03:37   Scan started
 1.01.1997   0:03:37   MODE: IDE
 1.01.1997   0:03:37   Device: FUJITSU MPF3204AH
 1.01.1997   0:03:37   F/W: 5C14
 1.01.1997   0:03:37   SN: 01187773
 1.01.1997   0:03:37   -------------------------------
 1.01.1997   0:03:37   Lap : 1
 1.01.1997   0:03:37   LBA scan: 0 to 40032695
 1.01.1997   0:15:10   ю LBA Warning: 35486055
 1.01.1997   0:17:15   Time spent: 00:13:36
 1.01.1997   0:17:15    Blocks <   3ms = 601
 1.01.1997   0:17:15    Blocks <  10ms = 156367
 1.01.1997   0:17:15    Blocks <  50ms = 22
 1.01.1997   0:17:15    Blocks < 150ms = 0
 1.01.1997   0:17:15    Blocks < 500ms = 1
 1.01.1997   0:17:15    Blocks > 500ms = 0
 1.01.1997   0:17:15   Errors: 0, Warnings: 1
 1.01.1997   0:17:15   Done
 1.01.1997   0:17:19
 1.01.1997   0:17:19   MHDD>SCAN
 1.01.1997   0:17:20   Scan started
 1.01.1997   0:17:20   MODE: IDE
 1.01.1997   0:17:20   Device: FUJITSU MPF3204AH
 1.01.1997   0:17:20   F/W: 5C14
 1.01.1997   0:17:20   SN: 01187773
 1.01.1997   0:17:20   -------------------------------
 1.01.1997   0:17:20   Lap : 1
 1.01.1997   0:17:20   LBA scan: 0 to 40032695
 1.01.1997   0:17:45   ю LBA Warning: 1377510
 1.01.1997   0:17:45   ю LBA Warning: 1377765
 1.01.1997   0:30:59   Time spent: 00:13:37
 1.01.1997   0:30:59    Blocks <   3ms = 616
 1.01.1997   0:30:59    Blocks <  10ms = 156348
 1.01.1997   0:30:59    Blocks <  50ms = 23
 1.01.1997   0:30:59    Blocks < 150ms = 2
 1.01.1997   0:30:59    Blocks < 500ms = 2
 1.01.1997   0:30:59    Blocks > 500ms = 0
 1.01.1997   0:30:59   Errors: 0, Warnings: 2
 1.01.1997   0:30:59   Done
 1.01.1997   0:33:00
 1.01.1997   0:33:00   MHDD>SCAN
 1.01.1997   0:33:02   Scan started
 1.01.1997   0:33:02   MODE: IDE
 1.01.1997   0:33:02   Device: FUJITSU MPF3204AH
 1.01.1997   0:33:02   F/W: 5C14
 1.01.1997   0:33:02   SN: 01187773
 1.01.1997   0:33:02   -------------------------------
 1.01.1997   0:33:02   Lap : 1
 1.01.1997   0:33:02   LBA scan: 0 to 40032695
 1.01.1997   0:44:35   ю LBA Warning: 35486055
 1.01.1997   0:46:40   Time spent: 00:13:37
 1.01.1997   0:46:40    Blocks <   3ms = 621
 1.01.1997   0:46:40    Blocks <  10ms = 156342
 1.01.1997   0:46:40    Blocks <  50ms = 27
 1.01.1997   0:46:40    Blocks < 150ms = 0
 1.01.1997   0:46:40    Blocks < 500ms = 1
 1.01.1997   0:46:40    Blocks > 500ms = 0
 1.01.1997   0:46:40   Errors: 0, Warnings: 1
 1.01.1997   0:46:40   Done
 1.01.1997   0:46:44
 1.01.1997   0:46:44   MHDD>SCAN
 1.01.1997   0:46:45   Scan started
 1.01.1997   0:46:45   MODE: IDE
 1.01.1997   0:46:45   Device: FUJITSU MPF3204AH
 1.01.1997   0:46:45   F/W: 5C14
 1.01.1997   0:46:45   SN: 01187773
 1.01.1997   0:46:45   -------------------------------
 1.01.1997   0:46:45   Lap : 1
 1.01.1997   0:46:45   LBA scan: 0 to 40032695
 1.01.1997   0:47:41   ю LBA Warning: 3133185
 1.01.1997   0:47:41   ю LBA Warning: 3133440
 1.01.1997   1:00:24   Time spent: 00:13:37
 1.01.1997   1:00:24    Blocks <   3ms = 618
 1.01.1997   1:00:24    Blocks <  10ms = 156347
 1.01.1997   1:00:24    Blocks <  50ms = 22
 1.01.1997   1:00:24    Blocks < 150ms = 2
 1.01.1997   1:00:24    Blocks < 500ms = 2
 1.01.1997   1:00:24    Blocks > 500ms = 0
 1.01.1997   1:00:24   Errors: 0, Warnings: 2
 1.01.1997   1:00:24   Done
 1.01.1997   1:00:52
 1.01.1997   1:00:52   MHDD>SCAN
 1.01.1997   1:00:54   Scan started
 1.01.1997   1:00:54   MODE: IDE
 1.01.1997   1:00:54   Device: FUJITSU MPF3204AH
 1.01.1997   1:00:54   F/W: 5C14
 1.01.1997   1:00:54   SN: 01187773
 1.01.1997   1:00:54   -------------------------------
 1.01.1997   1:00:54   Lap : 1
 1.01.1997   1:00:54   LBA scan: 0 to 40032695
 1.01.1997   1:02:41   ю LBA Warning: 5963940
 1.01.1997   1:02:41   ю LBA Warning: 5964195
 1.01.1997   1:12:30   ю LBA warning: 35486055
 1.01.1997   1:14:35   Time spent: 00:13:39
 1.01.1997   1:14:35    Blocks <   3ms = 627
 1.01.1997   1:14:35    Blocks <  10ms = 156308
 1.01.1997   1:14:35    Blocks <  50ms = 43
 1.01.1997   1:14:35    Blocks < 150ms = 10
 1.01.1997   1:14:35    Blocks < 500ms = 2
 1.01.1997   1:14:35    Blocks > 500ms = 1
 1.01.1997   1:14:35   Errors: 0, Warnings: 3
 1.01.1997   1:14:35   Done
 1.01.1997   1:14:46
 1.01.1997   1:14:46   MHDD>SCAN
 1.01.1997   1:14:50   Scan started
 1.01.1997   1:14:50   MODE: IDE
 1.01.1997   1:14:50   Device: FUJITSU MPF3204AH
 1.01.1997   1:14:50   F/W: 5C14
 1.01.1997   1:14:50   SN: 01187773
 1.01.1997   1:14:50   -------------------------------
 1.01.1997   1:14:50   Lap : 1
 1.01.1997   1:14:50   LBA scan: 0 to 40032695
 1.01.1997   1:17:38   ю LBA Warning: 9573975
 1.01.1997   1:17:38   ю LBA Warning: 9574230
 1.01.1997   1:26:23   ю LBA Warning: 35486055
 1.01.1997   1:28:28   Time spent: 00:13:37
 1.01.1997   1:28:28    Blocks <   3ms = 622
 1.01.1997   1:28:28    Blocks <  10ms = 156340
 1.01.1997   1:28:28    Blocks <  50ms = 26
 1.01.1997   1:28:28    Blocks < 150ms = 0
 1.01.1997   1:28:28    Blocks < 500ms = 3
 1.01.1997   1:28:28    Blocks > 500ms = 0
 1.01.1997   1:28:28   Errors: 0, Warnings: 3
 1.01.1997   1:28:28   Done
 1.01.1997   1:28:37
 1.01.1997   1:28:37   MHDD>EXIT
 1.01.1997   1:28:37   MHDD: Exit
Картина не изменилась.... сделал все кроме советов МмМ-а...
ИМХО дело в цирусе... глюкавый какой????
Из всех тестов один раз была рекалибровка (целий участок зелено-коричневій) А то идет скан... поверхность хорошая! Тут хоп-коричневый(<500ms).... Я канешно могу забить на это все, но мне интересно откуда беруться медленные куски там где их досель не было... а потом таким же мистическим макароном исчезают????
