Сборка с сайта под DOS включает 2 папки:
Сборка с сайта под DOS включает 2 папки: BIOS и KBC. В корневике лежит batник, вот его содержание:
cd kbc
call KBC.bat
wait64 5000
cd ..
cd BIOS
call BIOS.bat
Соответственно, содержание KBC.bat:
cd KBC
flupdate -bbl -novr -nocomp -noverify -noreboot -v -x 2 W0BAC112.bin -runbsf PchDec.bsf
И BIOS.bat
@echo off
set UMAROM=JV10V124.fd
set UMAWFEXE=JV10V124.exe
set UMAWF64EXE=JV10V124.exe
cls
if (%PROCESSOR_ARCHITECTURE%)==(x86) goto Winflash32
if (%PROCESSOR_ARCHITECTURE%)==(AMD64) goto Winflash64
:DOSMode
REM cd DOS
echo *********** JV10/SJV10-CS BIOS Flash Utility ***********
REM ***************************************************************
REM *** Just modify the above part ********************************
echo Notice:
echo 1. This procedure may replace your BIOS!
echo If you don't want to do it, press Ctrl-C to cancel.
echo 2. Make sure you plug in the AC adapter before flashing BIOS.
echo If not, DO NOT flash!
echo 3. This utility will check if the battery capacity is over 30%%.
echo If not, it will stop to flash the BIOS.
pause
ACERACDC
if errorlevel 255 goto DosFlash
goto end
:DosFlash
flashit Setup A04A27F4-DF00-4D42-B552-39511302113D /ev
flashit %UMAROM% /bios
goto end
:Winflash32
CLS
echo *** WinFlash Will start ,please wait ........... ***
cd..
cd ..
cd winflash
%UMAWFEXE%
goto end
:Winflash64
CLS
cd..
cd ..
cd winflash
%UMAWF64EXE%
goto end
:end
cd ..
