You are right! PWR is in AMD
PWM (ШИМ) working in VR11 or VR10 or AMD 6 bit mode?
You are right! PWR is in AMD mode( VID_SEL is - 0V) and VID 6 is not applicable and only VID 0-5 are in use.
Anyhow, When SEPRON is in socket all VIDs are 0V exept VID3 which is 2.3V.
What about VID1 pin where is 0.22V? I`ll try to track VID lines to CPU.
But 3,2 V is very high voltage for this circuit.
It is to high but with CPU present it drops to 1.xxV. I tried ATHLON X2 5200+ 65W (Acording to CPU compatibility list for this MOBO it`s not supported) and PWR generated 1.35V on hes supply. I don`t have another L6713a to try if he is broken or not. That would be fastest:)
