Dobrogo vremeni sytok/ y menya takaya problema -
Dobrogo vremeni sytok/ y menya takaya problema - pri vkluchenii pokazi'vaetsya soobchenie "No drive attached to the bios FastTrak controller, the Bios is not installed"/ a potom, kogda polnost'u zagruzitsua - vi'laziit okoshko "Exeption processing Message c0000013 Parameters 75b3bf7c 4 75b3bf7c 75b3bf7c" podskazhite pozh chto delat'/
zaranee spasibo)))
