Есть для 2k и для XP на M5289,
Есть для 2k и для XP на M5289, мб прикрутишь ими свой m5283.
Млин, прикрутил драйвер к новосозданному ядру 2.4.32, но что-то так и не увидел своего RAID Ali m5283 и винта котрый на нём висит тоже не увидаль=(
[root@FTP dev]# dmesg
Linux version 2.4.32 (root@FTP) (gcc version 3.2.2 20030222 (Red Hat Linux 3.2.2-5)) #3 Срд Фев 22 04:09:40 VLAT 2006
BIOS-provided physical RAM map:
 BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
 BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
 BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
 BIOS-e820: 0000000000100000 - 0000000004000000 (usable)
 BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
64MB LOWMEM available.
On node 0 totalpages: 16384
zone(0): 4096 pages.
zone(1): 12288 pages.
zone(2): 0 pages.
Kernel command line: BOOT_IMAGE=RH9(2.4.32) ro root=1601 BOOT_FILE=/boot/vmlinuz-2.4.32
Initializing CPU#0
Detected 167.045 MHz processor.
Console: colour VGA+ 80x25
Calibrating delay loop... 333.41 BogoMIPS
Memory: 62324k/65536k available (1336k kernel code, 2824k reserved, 496k data, 72k init, 0k highmem)
Dentry cache hash table entries: 8192 (order: 4, 65536 bytes)
Inode cache hash table entries: 4096 (order: 3, 32768 bytes)
Mount cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer cache hash table entries: 4096 (order: 2, 16384 bytes)
Page-cache hash table entries: 16384 (order: 4, 65536 bytes)
Intel Pentium with F0 0F bug - workaround enabled.
CPU:     After generic, caps: 008001bf 00000000 00000000 00000000
CPU:             Common caps: 008001bf 00000000 00000000 00000000
CPU: Intel Pentium MMX stepping 03
Checking 'hlt' instruction... OK.
POSIX conformance testing by UNIFIX
PCI: PCI BIOS revision 2.10 entry at 0xfb440, last bus=0
PCI: Using configuration type 1
PCI: Probing PCI hardware
PCI: Probing PCI hardware (bus 00)
Disabling direct PCI/PCI transfers.
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
Installing knfsd (copyright (C) 1996 ).
udf: registering filesystem
pty: 256 Unix98 ptys configured
Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI ISAPNP enabled
ttyS00 at 0x03f8 (irq = 4) is a 16550A
ttyS01 at 0x02f8 (irq = 3) is a 16550A
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
[drm] Initialized tdfx 1.0.0 20010216 on minor 0
[drm] Initialized radeon 1.7.0 20020828 on minor 1
Uniform Multi-Platform E-IDE driver Revision: 7.00beta4-2.4
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
hda: ASUS DVD-ROM DVD-E616P 0104, ATAPI CD/DVD-ROM drive
hdc: FUJITSU MPC3032AT, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
ide1 at 0x170-0x177,0x376 on irq 15
hdc: attached ide-disk driver.
hdc: 6346368 sectors (3249 MB), CHS=6296/16/63
hda: attached ide-cdrom driver.
hda: ATAPI 24X DVD-ROM drive, 256kB Cache
Uniform CD-ROM driver Revision: 3.12
Partition check:
 hdc: [PTBL] [395/255/63] hdc1 hdc2
Initializing Cryptographic API
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 4096 bind 8192)
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
VFS: Mounted root (ext2 filesystem) readonly.
Freeing unused kernel memory: 72k freed
Adding Swap: 128512k swap-space (priority -1)
Intel(R) PRO/1000 Network Driver - version 5.7.6-k1-NAPI
Copyright (c) 1999-2004 Intel Corporation.
e1000: eth0: e1000_probe: Intel(R) PRO/1000 Network Connection
e1000: eth0: e1000_watchdog: NIC Link is Up 100 Mbps Full Duplex
[root@FTP dev]#
Добавлено спустя 2 часа 8 минут 54 секунды:
Всё собралось на RH9.0!
Никто не поможет поправить дровишки на FreeBSD?
Исходники...
personal.primorye.ru/lsv/32bit_driver.rar
checksum: 64,5 КБ (66 084 байт)
P.S. Кому там дрова под Масдай нужны? Держите...
personal.primorye.ru/lsv/M5289_V.5.0.2.7.rar
checksum: 1,19 МБ (1 255 620 байт)
