2ROM you are right, there
2ROM > you are right, there is no user manual, however if you will pay attention all papers/docs/drivers are located @ ftp.packardbell.com/pub/itemnr/  there is quite a few folders and if you will get lucky you may find it there, also thought following links may help you in finding info on your problem :
uktsupport.co.uk/pb/pbidx.htm at the bottom you will find a couple urls to other packard bell sites and forums.
p.s. iGO 2000 as far as i understand is marketing name of the laptop, not technical - if know what i mean.
p.p.s. no comments on linguistic issue.
