Forum.PurePC.pl
Материал из Wiki.
<!-- start content -->
Przykład rozebrania _EN_CODE.BIN
Zapuskamy BIOS Patcher z kluczem "/t" - mamy fajla "lng_en.txt":
0000 <00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00>
0001 Disabled<00>
0002 Enabled <00>Disabled<00>
0003 None<00>
0004 X 2<00><00><00>
0100 Advanced BIOS Features<00>
0101 Advanced Chipset Features<00>
0102 PnP/PCI Configurations<00>
0103 Power Management Setup <00>
0104 Integrated Peripherals<00>
0105 H/W Monitor<00>
0106 Cell Menu<00><00>
0107 Load Fail-Safe Defaults<00>
0108 Load Optimized Defaults<00>
0109 <00>
010A <00>
010B <00>
010C <00>
010D <00>
010E Standard CMOS Features<00>
010F BIOS Setting Password<00>
0110 Save & Exit Setup<00>
0111 Exit Without Saving<00>
0112 Virus Protection, Boot Sequence...<00>
0113 AT clock, DRAM timings...<00>
0114 Sleep timer, Suspend timer...<00>
0115 IRQ Settings, Latency Timers...<00>
0116 Onboard IO, IRQ, DMA Assignment...<00>
0117 Load Fail-Safe Defaults<00>
0118 Load Optimized Defaults<00>
0119 Time, Date, Hard Disk Type...<00>
011A Display CPU/System Temperature, Fan speed<00>
011B Change CPU's Clock & Voltage<00>
011C Change/Set/Disable Password<00>
011D Save Data to CMOS<00>
011E Abandon all Data<00>
011F Press Enter<00>
0120 Press Enter<00>Press Enter<00>
0121 <00><00>
0122 <07-REVERSE><02-BRD 160B380F12><05-POS.180D>SAVE to CMOS and EXIT (Y/N)? <00>
0123 <07-REVERSE><02-BRD 170B370F12><05-POS.190D>Quit Without Saving (Y/N)? <00>
0124 Item Help<00>
0125 Press any key to continue...<00>
0126 <05-POS.0017> <18><19><1A><1B>:Move Enter:Select +/-/PU/PD:Value F10:Save ESC:Exit F1:General Help <05-POS.0018> F5:Previous Values F7: Optimized Defaults <00>
0127 <05-POS.0212>Esc : Quit <18> <19> <1A> <1B>  : Select Item<05-POS.0213>F10 : Save & Exit Setup <00>
0128 <07-REVERSE><02-BRD 0F0B400F02><05-POS.120D> Load Previous Values for this page (Y/N)? <00>
0129 <07-REVERSE><02-BRD 0F0B400F12><05-POS.110D>Load Fail-Safe Defaults for this page (Y/N)? <00>
012A <07-REVERSE><02-BRD 0F0B400F12><05-POS.110D>Load Optimized Defaults for this page (Y/N)? <00>
012B Main <00><00><00><00><00><00><00><00><00><00><00>
012C Advanced <00><00><00><00><00><00><00>
012D Power <00><00><00><00><00><00><00><00><00><00>
012E Defaults <00><00><00><00><00><00><00>
012F Security <00><00><00><00><00><00><00>
0130 Utilities <00><00><00><00><00><00>
0131 Exit <00><00><00><00><00><00><00><00><00><00><00>
0132 PC Health <00><00><00><00><00><00>
0133 Clk/Voltage <00><00><00><00>
0134 <00><00><00><00><00><00>
0135 <00><00><00><00><00><00>
0136 <00>
0137 <07-REVERSE><02-BRD 180C360F02><05-POS.1A0D>PASSWORD DISABLED !!! <09-BLINK><05-POS.1A0E><00>
0138 <07-REVERSE><02-BRD 180D360F02><05-POS.190E> Enter Password: <00>
0139 <05-POS.190E> Enter Password: <00>
013A <07-REVERSE><02-BRD 180D360F02><05-POS.1A0E>Confirm Password: <00>
013B <07-REVERSE><02-BRD 180C360F02><05-POS.1F0D>Invalid Password !<05-POS.1A0E>Press Any Key to Continue. <00>
013C <05-POS.1F0D>Invalid Password !<05-POS.1A0E>Press Any Key to Continue. <00>
013D <07-REVERSE><02-BRD 180D360F02><05-POS.200D>System Halted!!<00>
013E <08-NORM><02-BRD 180D360F02><05-POS.190E> System Halted!! <00>
013F <08-NORM><02-BRD 180D360F00><05-POS.190E> Enter Password: <00>
0140 <08-NORM><05-POS.190D> <05-POS.190E> <02-BRD 180C360F00><05-POS.1F0D>Invalid Password !<05-POS.1A0E>Press Any Key to Continue. <00>
0141 Load Optimized Defaults (Y/N)? <00><00>
0142 <13-SUBx01><07-REVERSE><02-BRD 160B390F13><05-POS.180D><00>
0143 Load Fail-Safe Defaults (Y/N)? <00>
0144 Load Optimized Defaults<00>
0145 F6 <00>
0146 F7 <00>
0147 IDE HDD Auto-Detection<00>
0148 & Exit SETUP<00>
0149 <02-BRD 05044A1501><02-BRD 0606490604><03-CLR 0605490505>!<05-POS.0647>eneral Help<08-NORM><00>
014A <18><19><1A><1B>  : Move<0b-BK>Enter  : Select<0b-BK>+/-/PU/PD : Value<0b-BK>ESC  : Exit<0b-BK>F1  : General Help<0b-BK>F2  : Item Help<0b-BK>F5  : Previous Values<0b-BK>F7  : Optimized Defaults<0b-BK>F10  : Save<00>
014B Menu Level <00>
0200 Assign IRQ For VGA <00>
0201 PCI/VGA Palette Snoop<00>
0202 IRQ Resource Arrange<00>
0203 Reset Configuration Data<00>
0204 Resources Controlled By<00>
0205 Auto(ESCD)<00>Manual <00>
0206 IRQ3 <00>
0207 IRQ4 <00>
0208 IRQ5 <00>
0209 IRQ7 <00>
020A IRQ9 <00>
020B IRQ10 <00>
020C IRQ11 <00>
020D IRQ12 <00>
020E IRQ14 <00>
020F IRQ15 <00>
0210 Available<00>Reserved <00>
0211 BIOS can automatically configure all the boot and Plug and Play compatible devices. If you choose Auto, you cannot select IRQ,DMA and memory base address fields, since BIOS automatically assigns them <00>
0212 Default is Disabled. Select Enabled to reset Extended System Configuration Data (ESCD) when you exit Setup if you have installed a new add-on and the system reconfiguration has caused such a serious conflict that the OS cannot boot <00>
0213 When resources are controlled manually, assign each system interrupt a type, depending on the type of device using the interrupt <00>
0214 Legacy ISA for devices compliant with the original PC AT bus specification, PCI/ISA PnP for devices compliant with the Plug and Play standard whether designed for PCI or ISA bus architecture <00><00><00><00>
0300 Jan<00>Feb<00>Mar<00>Apr<00>May<00>Jun<00>Jul<00>Aug<00>Sep<00>Oct<00>Nov<00>Dec<00>
0301 Sun,<00>Mon,<00>Tue,<00>Wed,<00>Thu,<00>Fri,<00>Sat,<00>
0302 Date (mm:dd:yy)<0c-ADDx0C><00>
0303 <0c-ADDx0F><0c-ADDx0C><00>
0304 Date (mm:dd:yy)<0c-ADDx0C><00><0c-ADDx05><00>
0305 Date (mm:dd:yy)<0c-ADDx0C><00><0c-ADDx09><00>
0306 Date (mm:dd:yy)<0c-ADDx0C><00><0c-ADDx0C><00>
0307 Time (hh:mm:ss)<0c-ADDx0C><00>
0308 Time (hh:mm:ss)<0c-ADDx0C><00><0c-ADDx03>: <0c-ADDx00><00>
0309 Time (hh:mm:ss)<0c-ADDx0C><00><0c-ADDx08>: <0c-ADDx00><00>
030A Base Memory <00>
030B Extended Memory <00>
030C Total Memory <00>
030D IDE Channel 0 Master <00>
030E IDE HDD Auto-Detection <00>
030F IDE Channel 0 Slave <00>
0310 IDE Channel 1 Master <00>
0311 IDE Channel 1 Slave <00>
0312 Capacity<00>
0313 Cylinder<00>
0314 Head<00>
0315 Precomp<00>
0316 Landing Zone<00>
0317 Sector<00>
0318 Access Mode<00>
0319 Floppy Drive A <00>
031A Drive B <00>
031B None <00>360K , 5.25 in.<00>1.2M , 5.25 in.<00>720K , 3.5 in. <00>1.44M, 3.5 in. <00>2.88M, 3.5 in. <00>
031C Halt On <00>
031D All Errors <00>No Errors <00>All , But Keyboard<00>Invalid <01-DIS>All , But Diskette<00>Invalid <01-DIS>All , But Disk/Key<00>
031E <00>
031F None <00><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS>Auto <00><01-DIS>Manual<00>
0320 None <00><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS>Auto <00>Manual<00><01-DIS>
0321 None <00><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS>Auto <00><01-DIS><01-DIS><01-DIS>Manual<00>
0322 None <00><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS><01-DIS>Auto <00><01-DIS><01-DIS>Manual<00>
0323 CHS <00>LBA <00>Large<00>Auto <00>-----<00>
0324 Change the day, month, year and century<00>
0325 Change the internal clock.<00>
0326 Press [Enter] to enter next page for detail hard drive settings<00>
0327 To auto-detect the HDD's size, head... on this channel<00>
0328 Selects the type of fixed disk.'User type' will let you select the number of cylinders, heads, etc.<0b-BK>Note: PRECOMP=65535 means NONE !<00>
0329 <00>
032A <00>
032B <00>
032C <00>
032D <00>
032E <00>
032F Auto <00>
0330 User <00>
0331 None <00>
0332 <07-REVERSE><02-BRD 160B390F02><05-POS.1C0D>Detecting Hard Drive...<00><08-NORM><09-BLINK>Press any key to continue...<00><00><00>
0400 Boot Sequence<00>
0401 Full Screen LOGO Show <00>
0402 Small Logo(EPA) Show<00>
0403 CPU L2 Cache ECC Checking<00>
0404 <00>
0405 Boot To OS/2<00>
0406 No<00>Yes<00>
0407 Select Yes if you are running OS/2 operating system with greater than 64MB of RAM on the system <00>
0408 1st Boot Device<00>
0409 2nd Boot Device<00>
040A 3rd Boot Device<00>
040B Select Your Boot Device Priority <00>
040C Boot From Other Device<00>
040D Boot Up NumLock Status<00>
040E Selects power on state for NumLock <00>
040F IDE HDD Block Mode<00>
0410 If your IDE hard drive supports block mode select Enabled for automatic detection of the optimal number of block read/writes per sector the drive can support <00>
0411 CPU Internal Cache<00>
0412 External Cache<00>
0413 Quick Booting<00>
0414 Allows the system to skip certain tests while booting. This will decrease the time needed to boot the system <00>
0415 Security Option<00>
0416 Setup <00>System<00>
0417 Select whether the password is required every time the system boots or only when you enter setup <00>
0418 Video BIOS Shadow<00>
0419 Enabled copies Video BIOS to shadow RAM Improves performance <00>
041A Off<00>
041B On <00>
041C Floppy <00>
041D Floppy <00>LS120 <00>Hard Disk <00>CDROM <00>ZIP100 <00>USB-FDD <00>USB-ZIP <00>USB-CDROM <00>LAN <00>Disabled <00>
041E IOAPIC Function<00>
041F MPS Table Version<00>
0420 1.1<00>1.4<00>
0421 Auto Detect PCI Clk<00>
0422 Spread Spectrum<00>
0423 CPU Clock<00>
0424 CPU Shutdown Temperature<00>
0425 60<F8>C/140<F8>F<00>65<F8>C/149<F8>F<00>70<F8>C/158<F8>F<00>Disabled <00>
0426 Chassis Intrusion<00>
0427 Disabled<00>Enabled <00>Reset <00>
0428 PC Health Status<00>
0429 System Temperature<00>
042A CPU Temperature<00>
042B CPU Temperature<00>
042C CPU Vcore<00>
042D +3.3V <00>
042E 5V <00>
042F 3.3V <00>
0430 VIN2<00>
0431 VBAT (V)<00>
0432 5VSB (V)<00>
0433 System FAN Speed<00>
0434 CPU FAN Speed<00>
0435 Fan3 Speed<00>
0500 <00>
0501 CMOS checksum error - Defaults loaded<00><00>
0502 CMOS battery failed<00><00>
0503 Override enabled - Defaults loaded<00><00>
0504 , An Energy Star Ally<00><00>
0505 Memory Testing : <00>
0506 K OK<00>
0507 K: <00>
0508 Main Processor : <00>
0509 Display switch is set incorrectly.<00>
050A Keyboard is locked out - Unlock the key<00>
050B Keyboard error or no keyboard present<00>
050C Memory test fail<00>
050D <05-POS.001C> <05-POS.001C><08-NORM>Press <06-HILITE>F1<08-NORM> to continue,<15><11-COLOR 05> <00>
050E <05-POS.0017><08-NORM>Press <06-HILITE>F1<08-NORM> to continue,<15><11-COLOR 05> <00>
050F <05-POS.0EFF><00>
0510 <05-POS.001C><08-NORM>Press<15><11-COLOR 05><15><12-WARNING><05-POS.0020><06-HILITE>
0511 <06-HILITE>DEL<08-NORM> to enter SETUP<00>
0512 <08-NORM>, <06-HILITE><F11><08-NORM> to Enter Boot Menu<00>
0513 <05-POS.001C><08-NORM> <00>
0514 <05-POS.0017><08-NORM>Press <06-HILITE>DEL<08-NORM> to enter SETUP<05-POS.0017><08-NORM>
0515 <05-POS.0017><08-NORM> <00>
0516 Floppy disk(s) fail ( )<13-SUBx03><00>
0517 Hard disk(s) Diagnosis fail<00>
0518 Primary master hard disk fail<00>
0519 Primary slave hard disk fail<00>
051A Secondary master hard disk fail<00>
051B Secondary slave hard disk fail<00>
051C <0a-LF><0d-CR><06-HILITE>Warning:<08-NORM>The boot devices have been changed.<0a-LF><0d-CR>BBS boot priority will be affected.Please enter setup to check<0a-LF><0d-CR><00>
051D <05-POS.321C><08-NORM>, <06-HILITE>ESC<08-NORM> to skip memory test<00>
051E <05-POS.321C><08-NORM>, <06-HILITE>ESC<08-NORM> to skip memory test<00>
051F <05-POS.321C><08-NORM> <00>
0520 <03-CLR 001B4F1D00><05-POS.321C><08-NORM>
0521 <05-POS.321C><08-NORM> <00>
0522 <03-CLR 00164F1800><05-POS.001D><08-NORM>
0523 <05-POS.001D><08-NORM>Press <06-HILITE>TAB<08-NORM> to show POST screen,<15><11-COLOR 05><15><12-WARNING><05-POS.2020> <00>
0524 <07-REVERSE><03-CLR 00004F1D00>Conflict I/O Ports : <00>
0525 Conflict I/O Ports : <00>
0526 <B4> <18><19>:Move Enter:Accept F4:Exit <C3><00>
0527 No Bootable Device Found<00>
0528 == Select a Boot First device ==<00>
0529 Boot Menu<00>
052A Hard Disk<00>
052B <DA><00>
052C <BF><00>
052D <C0><00>
052E <D9><00>
052F <C3><00>
0530 <B4><00>
0531 <C4><00>
0532 <B3><00>
0533 <00>
0534 +<00>
0535 ,<00>
0536 CPUs<00>
0537 <0e-ADDy01><08-NORM><0d-CR>Detecting IDE drives ...<00>
0538 None <00>
0600 Onboard FDC Controller: <00>
0601 COM Port 1<00>: <00>
0602 Disabled <00>3F8/IRQ4 <00>2F8/IRQ3 <00>3E8/IRQ4 <00>2E8/IRQ3 <00>Auto <00>
0603 COM Port 2<00>: <00>
0604 Parallel Port: <00>
0605 Disabled<00>378/IRQ7<00>278/IRQ5<00>3BC/IRQ7<00>AUTO <01-DIS>
0606 Parallel Port Mode: <00>
0607 SPP <00>EPP <00>ECP <00>ECP+EPP<00>Normal <00>
0608 UART Mode Select: <00>
0609 IrDA <00>ASKIR <00>Normal<00>
060A RxD , TxD Active: <00>
060B Hi,Hi<00>Hi,Lo<00>Lo,Hi<00>Lo,Lo<00>
060C IR Transmission Delay: <00>
060D UR2 Duplex Mode: <00>
060E Full<00>Half<00>
060F Use IR Pins: <00>
0610 RxD2,TxD2<00>IR-Rx2Tx2<00>
0611 ECP Mode Use DMA: <00>
0612 1<00>3<00>
0613 EPP Mode Select: <00>
0614 EPP1.9<00>EPP1.7<00><00>
0700 Hard Disk Boot Priority<00>
0701 Select Hard Disk Boot Device Priority<00>
0702 1. <00>
0703 2. <00>
0704 3. <00>
0705 4. <00>
0706 5. <00>
0707 6. <00>
0708 7. <00>
0709 8. <00>
070A Pri.Master: <00>Pri.Slave : <00>Sec.Master: <00>Sec.Slave : <00>USBHDD0  : <00>USBHDD1  : <00>USBHDD2  : <00>Bootable Add-in Cards <00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00><00>
070B Use <<18>> or <<19>> to select a device , then press <+> to move it up , or <-> to move it down the list. Press <ESC> to exit this menu.<00>
070C <05-POS.0017> <18><19>:Move PU/PD/+/-:Change Priority F10:Save ESC:Exit <05-POS.0018> F5:Previous Values F7:Optimized Defaults <00>
070D Ch0 M.  : <00>Ch0 S.  : <00>Ch1 M.  : <00>Ch1 S.  : <00>Ch2 M.  : <00>Ch2 S.  : <00>Ch3 M.  : <00>Ch3 S.  : <00>Ch4 M.  : <00>Ch4 S.  : <00>Ch5 M.  : <00>Ch5 S.  : <00>Ch6 M.  : <00>Ch6 S.  : <00>Ch7 M.  : <00>Ch7 S.  : <00>
070E SCSI-0  : <00>SCSI-1  : <00>SCSI-2  : <00>SCSI-3  : <00>SCSI-4  : <00>SCSI-5  : <00>SCSI-6  : <00>SCSI-7  : <00>
070F USB-HDD0  : <00>USB-HDD1  : <00>USB-HDD2  : <00>USB-HDD3  : <00>USB-HDD4  : <00>USB-HDD5  : <00>
0710 Not Installed<00>
0800 Cool'n'Quiet control<00>
0801 Auto <00>Disable<00>
0802 DRAM Configuration<00>
0803 DRAM timing and control<00>
0804 Places an artificial memory clock limit on the system. Memory is prevented from running faster than this frequency.<00>
0805 1T/2T Memory Timing  : <00>
0806 1T <00>2T <00>Auto<01-DIS>
0807 Limit - the frequency is further limited by the value specified<00>
0808 Memclock index value (Mhz)<00>
0809 <01-DIS>100Mhz<00>133Mhz<00><01-DIS>166Mhz<00>183Mhz<01-DIS>200Mhz<00>216Mhz<00>233Mhz<00>250Mhz<00><01-DIS>
080A Timing Mode<00>
080B Auto <00>Manual<00>
080C CAS# latency (Tcl)<00>
080D <01-DIS>2 <00>2.5<00>3 <00>
080E Min RAS# active time(Tras) <00>
080F Auto<00><01-DIS><01-DIS><01-DIS><01-DIS> 5T<00> 6T<00> 7T<00> 8T<00> 9T<00>10T<00>11T<00>12T<00>13T<00>14T<00>15T<00>
0810 RAS# to CAS# delay (Trcd) <00>
0811 Auto<00><01-DIS> 2T<00> 3T<00> 4T<00> 5T<00> 6T<00> 7T<00>
0812 Row precharge Time (Trp) <00>
0813 Row to Row delay (Trrd): <00>
0814 2T<00> 3T<00> 4T<00>Auto<00>
0815 User Config mode<00>
0816 DRAM Bank Interleaving<00>
0817 Bank Interleaving interlock<00>
0818 At Least not<00>All Present are<00>
0819 Burst Length<00>
081A 8 beats<00>4 beats<00>2 beats<00>
081B Enable All DIMM slots clock<00>
081C Read Preamble value<00>
081D 2ns <00>2.5ns<00>3ns <00>3.5ns<00>4ns <00>4.5ns<00>5ns <00>5.5ns<00>6ns <00>6.5ns<00>7ns <00>7.5ns<00>8ns <00>8.5ns<00>9ns <00>9.5ns<00>
081E Async Latency value<00>
081F 2ns <00>3ns <00>4ns <00>5ns <00>6ns <00>7ns <00>8ns <00>9ns <00>10ns <00>11ns <00>
0820 Bottom of 32-bit[31:24] IO<00>
0821 S/W memory hole Remapping<00>
0822 H/W memory hole Remapping<00>
0823 H/W memory hole interlock<00>
0824 Node memory Interleaving<00>
0825 Node Interleaving interlock<00>
0826 Large Memory Simulation<00>
0827 Disable<00>4GB<00><01-DIS><01-DIS>
0828 MTRR mapping mode<00>
0829 Continuous<00>Discrete<00>
082A System BIOS Cacheable<00><00><00>
0900 <0e-ADDy01><08-NORM><0d-CR>Detecting IDE drives ...<00>
0901 None <00>
0902 <08-NORM><0d-CR>IDE Channel 0 Master :<00>
0903 <08-NORM><0d-CR>IDE Channel 0 Slave  :<00>
0904 <08-NORM><0d-CR>IDE Channel 1 Master :<00>
0905 <08-NORM><0d-CR>IDE Channel 1 Slave  :<00>
0906 <0e-ADDy01><08-NORM><0d-CR>Detecting IDE drives ...<00>
0907 <08-NORM><0d-CR>IDE Channel 2 Master :<00>
0908 <08-NORM><0d-CR>IDE Channel 2 Slave  :<00>
0909 <08-NORM><0d-CR>IDE Channel 3 Master :<00>
090A <08-NORM><0d-CR>IDE Channel 3 Slave  :<00>
090B IDE Channel 0 . Master Disk <00>
090C IDE Channel 1 . Master Disk <00>
090D IDE Channel 0 . Slave Disk <00>
090E IDE Channel 1 . Slave Disk <00>
090F IDE Channel 2 . Master Disk <00>
0910 IDE Channel 3 . Master Disk <00>
0911 IDE Channel 2 . Slave Disk <00>
0912 IDE Channel 3 . Slave Disk <00>
0A00 IDE Channel 2 Master<00>
0A01 IDE Channel 2 Slave<00>
0A02 IDE Channel 3 Master<00>
0A03 IDE Channel 3 Slave<00>
0A04 IDE Auto-Detection<00>
0A05 Extended IDE Drive<00>
0A06 None <00>Auto <00>
0A07 Large<00>Auto <00><00><00>
0B<ABSENT>
0C00 IDE Devices Configuration <00>
0C01 VIA OnChip PCI Device <00>
0C02 IO Devices Configuration <00>
0C03 Press Enter<00>Press Enter<00>
0C04 OnChip SATA<00>
0C05 SATA Mode<00>
0C06 IDE <00>RAID<00>
0C07 IDE Mode only for WinXP<00>
0C08 IDE DMA transfer access<00>
0C09 OnChip IDE Channel0<00>
0C0A OnChip IDE Channel1<00>
0C0B IDE Prefetch Mode<00>
0C0C Primary Master PIO<00>
0C0D Primary Slave PIO<00>
0C0E Secondary Master PIO<00>
0C0F Secondary Slave PIO <00>
0C10 Auto <00>Mode 0<00>Mode 1<00>Mode 2<00>Mode 3<00>Mode 4<00>
0C11 Primary Master UDMA<00>
0C12 Primary Slave UDMA<00>
0C13 Secondary Master UDMA<00>
0C14 Secondary Slave UDMA<00>
0C15 Disabled<00>Auto <00>
0C16 AC97 Controller<00>
0C17 Enabled <00>Disabled<00>
0C18 Onboard LAN Controller<00>
0C19 Enabled <00>Disabled<00>
0C1A Onboard LAN Option ROM <00>
0C1B Decide whether to invoke the boot ROM of the onboard LAN chip<00>
0C1C USB Controller <00>
0C1D All Disabled<00>All Enabled <00>1&2 USB Port<01-DIS>2&3 USB Port<01-DIS>1&3 USB Port<01-DIS>1 USB Port<01-DIS>2 USB Port<01-DIS>3 USB Port<01-DIS>
0C1E All Disabled <00>All Enabled <00>1&2 USB Port <00>1&2&3 USB Port<00>1&3 USB Port <00>1 USB Port <00>2 USB Port <00>3 USB Port <00>
0C1F OnChip EHCI Controller<00>
0C20 USB Device Function<00>
0C21 USB Keyboard Support<00>
0C22 USB Mouse Support<00>
0C23 USB Device Legacy Support <00>
0C24 Disabled<00>KB/MS <01-DIS>Enabled <00>
0C25 Disable -<0b-BK>Don't support any USB device on DOS.<0b-BK><0b-BK>Enable -<0b-BK>Support USB legacy Keyboard, Mouse and Storage.<00>
0C26 Onboard Lan Device<00>
0C27 Control_Onchip_Str<00>
0C28 Primary Graphic's Adapter<00>
0C29 PCI Slot<00>Onboard <01-DIS>AGP <00><00><00>
0D00 Press Enter<00>Press Enter<00>
0D01 ACPI function<00>
0D02 ACPI Standby State<00>
0D03 S1(POS)<00>S3(STR)<00>Auto <01-DIS> <01-DIS>
0D04 Power Management Option<00>
0D05 User Define<00>Disabled <01-DIS>Min Saving <00>Max Saving <00>
0D06 HDD Power Down<00>
0D07 Disable<00> 1 Min <00> 2 Min <00> 3 Min <00> 4 Min <00> 5 Min <00> 6 Min <00> 7 Min <00> 8 Min <00> 9 Min <00>10 Min <00>11 Min <00>12 Min <00>13 Min <00>14 Min <00>15 Min <00>
0D08 PM Timers<00>
0D09 Suspend Time Out (Minute)<00>
0D0A Disable<00> 5 Sec <01-DIS>10 Sec <01-DIS>20 Sec <01-DIS>30 Sec <01-DIS>40 Sec <01-DIS> 1 Min <00> 2 Min <00> 4 Min <00> 6 Min <00> 8 Min <00>10 Min <00>20 Min <00>30 Min <00>40 Min <00> 1 Hour<00>
0D0B Wake Up Event Setup<00>
0D0C Resume From S3 by PS/2 KB <00>
0D0D Hot key <00>Password<00>
0D0E When Select Password, Please press ENTER key to change Password Max 8 numbers.<00>
0D0F Resume By PS/2 Keyboard <00>
0D10 Disable <00>Ctrl+F1 <00>Ctrl+F2 <00>Ctrl+F3 <00>Ctrl+F4 <00>Ctrl+F5 <00>Ctrl+F6 <00>Ctrl+F7 <00>Ctrl+F8 <00>Ctrl+F9 <00>Ctrl+F10<00>Ctrl+F11<00>Ctrl+F12<00>Power <00>Wake <00>Any Key <00>
0D11 Resume By PS/2 Mouse<00>
0D12 Resume From S3 By USB<00>
0D13 VGA<00>
0D14 LPT & COM<00>
0D15 NONE <00>LPT <00>COM <00>LPT/COM<00>
0D16 HDD & FDD<00>
0D17 PCI Master  : <00>
0D18 Primary INTR<00>
0D19 Resume by PCI Device(PME#)<00>
0D1A Resume By RTC Alarm <00>
0D1B Modem Ring Resume<00>
0D1C Date (of Month)<00>
0D1D Resume Time (hh:mm:ss)<0c-ADDx04><00>
0D1E Resume Time (hh:mm:ss)<0c-ADDx04><00><0c-ADDx03>: <13-SUBx01><00>
0D1F Resume Time (hh:mm:ss)<0c-ADDx04><00><0c-ADDx08>: <13-SUBx01><00>
0D20 <00>
0D21 Power Button Function<00>
0D22 Suspend <00>Power Off<00>
0D23 Re-call VGA BIOS from S3<00>
0D24 Auto <00>Yes <00>No <00>Rev <01-DIS>
0D25 Restore On AC Power Loss<00>
0D26 Off <00>On <00>Last State<00>Rev <01-DIS>
0D27 IRQs Activity Monitoring<00>
0D28 IRQ3 (COM 2)<00>
0D29 IRQ4 (COM 1)<00>
0D2A IRQ5 (LPT 2)<00>
0D2B IRQ6 (Floppy Disk)<00>
0D2C IRQ7 (LPT 1)<00>
0D2D IRQ8 (RTC Alarm)<00>
0D2E IRQ9 (IRQ2 Redir)<00>
0D2F IRQ10 (Reserved)<00>
0D30 IRQ11 (Reserved)<00>
0D31 IRQ12 (PS/2 Mouse)<00>
0D32 IRQ13 (Coprocessor)<00>
0D33 IRQ14 (Hard Disk)<00>
0D34 IRQ15 (Reserved)<00>
0D35 OFF<00>ON <00>
0D36 Video Off Option<00>
0D37 Always On <00>Suspend -> Off <00>????????????????<01-DIS>
0D38 MODEM Use IRQ<00>
0D39 NA<00>??<01-DIS>??<01-DIS>3 <00>4 <00>5 <00>??<01-DIS>7 <00>??<01-DIS>9 <00>10<00>11<00>??<01-DIS>??<01-DIS>??<01-DIS>??<01-DIS>
0D3A Video Off Method<00>
0D3B Blank Screen <00>V/H SYNC+Blank<00>??????????????<01-DIS>DPMS Support <00><00><00>
0E00 LDT & PCI Bus Control<00>
0E01 66 MHz<00>
0E02 100 MHz<00>
0E03 133 MHz<00>
0E04 166 MHz<00>
0E05 200 MHz<00>
0E06 MHz<00>
0E07 Current CPU Clock<00>
0E08 Current DRAM Frequency <00>
0E09 Memory Hole<00>
0E0A Disabled <00>512K-640K<01-DIS>15M - 16M<00>14M - 16M<01-DIS>
0E0B Upstream LDT Bus Width<00>
0E0C Downstream LDT Bus Width<00>
0E0D 8 bit<00>16 bit<00>
0E0E LDT Bus Frequency<00>
0E0F Auto <00> 1 GHz<00>800 MHz<00>600 MHz<00>400 MHz<00>200 MHz<00>
0E10 PCI1 Master 0 WS Write<00>
0E11 PCI2 Master 0 WS Write<00>
0E12 PCI1 Post Write<00>
0E13 PCI2 Post Write<00>
0E14 PCI Delay Transaction<00>
0E15 Delay Transaction<00>
0E16 VLink Data Rate<00>
0E17 8X <00>4X <00>
0F00 AGP Aperture Size<00>
0F01 32M <00>64M <00>128M<00>256M<00>512M<00>1G <00>
0F02 AGP 2.0 Mode<00>
0F03 4X<00>2X<00>1X<00>
0F04 AGP3.0 Mode<00>
0F05 8X<00>4X<00>XX<01-DIS>
0F06 AGP Driving Control<00>
0F07 Auto <00>Manual<00>
0F08 AGP Driving Value<00>
0F09 AGP Fast Write<00>
0F0A AGP 3.0 Calibration cycle<00>
0F0B DBI Output for AGP Trans.<00>
0F0C Auto <00>Disabled<00>
0F0D AGP Master 1 WS Write<00>
0F0E AGP Master 1 WS Read<00>
0F0F AGP & P2P Bridge Control<00><00>
1000 Memory Voltage(V)<00>
1001 2.55<00>2.5 <00>2.6 <00>2.65<00>2.7 <00>2.75<00>2.8 <00>2.85<00>
1002 AGP Voltage(V)<00>
1003 1.5<00>1.55<00>1.6 <00>1.65<00>1.7 <00>1.75<00>1.8 <00>1.85<00>
/end
>...najbardziej interesującej mnie części czyli podniesienia max HTT Z 232MHz do dajmy na to 250. Jakieś sugestie?
Jakego punkta masz na myśli?
0 MB
Подробнее о форматировании
CAPTCHA
Перед отправкой сообщения ответьте на вопрос.
finge_print:
RSS-материал
